Creamsource Vortex fixture profile no longer carries the control channel functions in HogOS v4.
The 8th channel is blank in the personality.
best
D
best
D
Hello,
Can you please specify which Model and Mode Vortex fixture? We will correct it, and I will post it here once it is completed. Thank you
The Vortex 4 personality. All modes. Vortex 8 personalities are correct.
Copy, thank you. We'll get this corrected as soon as we can.
Hello again, until this is resolved, you can use the Vortex 8 library as it is directly compatible and has the control modes. Alternately, you can copy the library into fixture builder and change the name to "Vortex 4" and patch it accordingly. I hope this helps in the interim.
