Track Sheet
Does anyone else find it troublesome programming shows on Hog4 without a track sheet? It makes it very hard to work out which fixtures are available to be added into programming, or which cues to remove data from.
  • If you need to know which cues/scenes/palettes contain which fixture data, that can be found using Reporting.  Hold "Open", then select "Report"
    Find programming that matches "All of the following"
    is For Fixtures of Type "Lonestar" or is "For Fixture" (user #)
    (run)
    Report will show all locations of that fixture type
