Compatibility between Miniwing 4 and Hog Tour
Hi everyone,
I'm currently working on a lighting setup and I was wondering if anyone has experience using the miniWing 4 in combination with the ETC Hog Tour.
Are these two units compatible in terms of control protocols and software integration?
In particular, I've encountered some serious issues:
- When the miniWing 4 is connected by USB before Power on the Hog Tour, it prevents the console from starting properly.
- If I connect the miniWing 4 after power on and just before launching the show, the console crashes and becomes unresponsive.
Specifically, I'm interested in knowing whether the miniWing 4 can be used as an extension or controller for the Hog Tour system and if there are any limitations with the release 5.0.0 b937 or setup requirements I should be aware of.
Any insights or experiences would be greatly appreciated!
Thanks in advance.
