We have just installed 5.0.1 on a Full Boar 4 with a Rev 2 Hog 4 wing. We have observed the following behaviour
- Version display option for Rev 2 causes the wing not be recognised as a screen, although the faders do work.
 - Custom screen allows the screen to be used, however the resolutions do not have an appropriate effect (Rev 2 resolution should be 1366 x 768, however setting the custom display to this resolution does not scale the output correctly to match).
 - Text does not scale correctly with resolution changes (i.e. the Toolbar text remains very small)
 - Restarts reset the resolution to 1080p
 - Calibration changes the display theme from dark to mid greys, and does not return them at the completion of calibration. The only way to get back to the dark theme short of a restart is to go into preferences, change the theme to stealth or light, apply the change, then change the theme to Dark again.
Hoping this can be resolved, because when me move to a Hog 5, our hope is to take the fader wing with us.
