I want to use the HOG5 software on my HOG4 Nano. Since all the HOG5 Hardware has 5 encoders, this is embedded in the software. Is there a place where I can set the amount of encoders to 4, so no kinds are using the 5th encoder?
Before you load your show, you can set in the control panel that HogPC has to start in Nano Mode. You will get then you 4 encoders as it was in v4
EJBerendsen
