Hello,
With the absence of the lower right softkey presses in v5.0.1 I was trying to use a screen press of "Replace" on the programming dashboard but found that screen presses are not registered on dashboards in v5.0.1. Is this intentional? Whilst ideally these options would be directly available as Command Data (in Programming Keys list) it would still be better to use a dashboard press rather than a screen press on the toolbar on the main display which cannot be guaranteed to be open when the macro is run.
Cheers
Colin
