Can’t get color into scene on hog 5 PC
We are setting up hog 5 on PC and made color palettes using groups. We are picking colors from the color palette that we know work, attaching them to a scene, and when opening the scene the color mixing values are correct. When we click on the scene to use it however, the lights do not change color, even though we know they should work. Please help!
  • Hello, is the Guard button in the upper left Blue or Gray?  If it's blue, Guard is on and when you hit a button in the directory, it will only place the object in the syntax line.  Touching the Guard button will toggle it on and off.  It will turn gray (off), and then your scenes should trigger.  Touch Guard again, it will turn blue (on) and your scenes won't go.
