Tour Hog Fixture builder
Date - 1.27.26
Console - Tour Hog
Software - V5.0.1 b.135
Issue - Building a show file and found that an existing library was built incorrectly (Acme Tornado 85ch).  When I go into fixture builder, I can copy type and correct the issue.  However, when I save the corrected library, it reorders the compound fixture.  For example, it show be as follows:
1. - Master
1.1 - Cell 1
1.2 - Ring 1
1.3 - Cell 2
1.4 - Ring 2
1.5 - Cell 3
1.6 - Ring 3
1.7 - Cell 4
1.8 - Ring 4
1.9 - Cell 5
1.10 - Ring 5
Now, the newly corrected fixtures starts at 1.1 and ends at 1.11.  The master is at 1.11 instead of 1.  The only change made to the library was the order of the intensity channel on the cells (1.1, 1.3, 1.5, 1.7, 1.9)  Nothing changed on the order of the master.  Looking at the completed revised fixture, it matches exactly the layout of the onboard library.
Is anyone else seeing this in the Fixture Builder?
Jon Weir
