Bug Report - Change Type - Tour Hog
Date - 1.27.26
Console - Tour Hog
Software - V5.0.1 b.135
Issue -Change type is not working with compound fixtures.  It works on regular fixtures, but is a no go with compound fixtures.
  • Hi,
    Change type has never worked directly ( to the best of my understanding) with Hog with any software version.You can try "exploding" fixtures that are not compound and then changing type of the individual fixture parts and the same with compound fixtures .
    You end up with multiple fixture types which you then have to repatch and sort out into groups , time consuming but it does work.
    I'm not using s/w V5 so unclear if you are suggesting change type is not working at all.
    Best C
  • Apologies,my previous post said change type has never worked which is incorrect, what I meant to say is change type with compound fixtures has never been a feature or worked as expected.
    Thank you
