Bug Report - Encoder Wheel Sensitivity and Percentage
Date - 2.10.26
Console - Tour Hog
Software - V5.0.1 b.135
Issue - If sensitivity is set to max value, the encoder wheels respond in steps.  Adjusting parameters such as intensity or pan/tilt the values move in jumps of 3 or 4 percent.  If pressing CHOOSE and adjusting FX speed, it moves in jumps of 6 percent.
Issue 2 - If you move the encoder wheel very slowly, the value does not change at all.  I can slowly spin and encoder all the way around and it will not register until I quickly "bump" the wheel and then it will start moving.
If I press the wheel, then move it, it responds quicker, but still moves in jumps.
