Hi all
I have a line of 60 leds RGBW and I want to make an intesity effect where a group of 6 leds light up and run all the line and bounce back. I think I tried everything but I cant do it. All other int fxs run normally. I am using HOG4 4.3.0
Hi all
Based on what you just said I think you need to just select in the right order.
set effect intensity to sign or whatever wave you like.
set buddy to six and adjust the timing, set direction to bounce.
