5.10 Fader behavior
HogPC V5.1 Fader behavior
Setup:
- HogPC on win 11 with Nano connected
Issue:
- HTP Faders and IPCB Faders loose track in the middle of use.
This happens since 5.01 and I guess this is related to the new Master ranges.
As an example: Using two HTP faders odd/even as softer beat changes, one fader sometimes would be stuck at a certain percentage as if you would come from a different page and you regain access only when you are getting back to that percentage.
The same happens to IPCB Masters. Never had this issue in pre V5 Software
  • This is an issue that is logged in versions up to v5.2 where non-motorized faders become "unlatched" from the actual value, even without changing pages.  This issue has been confirmed and logged in our system.  The software developers are working to resolve some of the lingering bugs like this one.  Unfortunately, I don't have a definitive timeline for when it will be fixed.
