Bug - Tour Wing U keys "Master Ranges" function
v5.2 b212
Tour Hog + Tour Wing
Keys U9 + U10 set to Master Range + or - switch master ranges not on a Wing, but on a Tour Hog.
They should be separated.
  • YES! Its true and we got into the discussion on how this should work. Should they be linked together, your console and your wing or should they be separate and how would Master Range + - work?
    If the Wing is on the left side, can you set the wing to Playback 1-10 and your console to 11-20 and lock this together?
    Or would Master Range assigned to U-keys (9-12) on the Wing do only the wing and on the console (1-8) only affect the console except when they are linked (console and wing), then the Master Range + - would affect both?
    Cheers Sander
  • I would say there should be basically a Wing Setup tab in the preferences where you can do everything you need to.
    Wing separate check-box - when checked, the Master range + and - work just for the wing. Unchecked - Wing's master range and console's master ranges are connected and U-buttons change the master range on the wing and the console together.
    Wing Left/Right selection might affect the numbering of masters.
    Just as an example.
