HOG PC 5.2.0
Using a Hog Nano with 2 super widgets and a Gadget usb key. Console has 10 universes unlocked but the processor stalls when using sACN out puts.
Itis technically outputting but there is a 10-30 second delay.
Ie select lights and give them a title value. The encoder dashboard is displaying the correct information on the wheel sets but the dmx window is not showing the values change live as it does normally.
Only using 1 copper line direct to the console today and solved the issue by removing all the sACN mappings. Everything then returned to normal.
Not using the network port today so maybe that’s the problem?
Any help would be greatly appreciated.
Thanks for reading,
Josh
