How to right-click on RH4? (to change displayed columns)
Hi!
On Hog4Pc I can right-click on the column headings in the Programmer/Editor window to modify the displayed columns (e.g. choose to "Show Note"). Is there a way to open this context menu on the RoadHog4 without external mouse? I tried Pig+Set or Pig+touching the column but nothing is happening.
Grateful for any help!! It's been a pleasure using hog so far!
Thanks, Axel
  • Pig + Set should be a right-mouseclick. This is not working exactly as it does with a mouse attached. If you want to color a directory item which you normally can do with a right mouse-click, this wont work with Pig + Set. To solve this i go into Spreadsheet Mode, select de Color column and pres Set to give it a color.
    Don't have a work around for your question other than Bring a Mouse Slight smile
