Recall from on Hog4
I switch between EOS and Hog often. One thing that I find myself missing is the recall from button on the EOS. Is there an equivalent way to do that on the Hog? An example being when I have one unit programmed and want to replicate what it is doing with another unit. Nothing is saved in pallets, just want to grab the current position or color etc from one unit and copy it to another.
  • You can do this with Copy. Select the fixture you want to recall and type Cue N Copy Enter. You can use masking to bring select parameters in to the programmer. You can read all about it in sec 6.3.8 of the manual.
  • Functions like Suck and Touch come handy. For example if you are in the current cue where Fixture 101 has position, color and gobo which you also want to use for Fixture 116 you type the following syntax: 101 touch enter 101 copy 116 enter
    All the values that fixture 101 has in that cue (also tracking values from previous cues) are sucked into the programmer without all default values.
    Than you can copy the values to an other fixture and save it where you want. Maybe you want to knockout the Fixture 101 so it doesn't also get stored.
    If its in the same List and Cue you can also use the syntax: List 4 Cue 3 Fixture 101 Copy Fixture 116
