Hello everyone!
I’m trying to connect Hog4PC direct to Lightconverse on the same machine without success.
I downloaded the Connectivity Application (www.flyingpig.com/support/hog3/downloads/VisualizerConnectivity.shtml.foo) and followed the guide (lightconverse.net/lc/download/lightconverse_hog3%20direct%20connection%20guide.pdf) carefully.
The guide says on the first page: „2. As LIGHTCONVERSE opens, a Wholehog DP dialog box will open at the bottom right of your computer screen and a Hog icon will be placed in the Windows task bar„. But this isn’t the case.
I tried different versions of the Visualizer Connectivity tool, uninstalled it and installed it again. I’m using Windows 8.1.
I think the main problem is, that the previous installed Lightconverse (Net-In Version with dongle, installed months before Hog4PC), doesn’t launch this Connectivity tool. It’s another version of Lightconverse, then the one shipped as accessory to the hog consoles, but it supports HOG-Net (fixtures are patched on HOG-Net).
Does anyone have an idea or any experience with this problem?
Thanks in advance!
Best,
Lydia
