Cue Macro - Choose Current Master "CM Current"
I would like the ability to "Choose Current Master" when a cue/list is activated.
We currently can set a Cue macro to CM# to select a specific master number by numbeer.   Often, when I have a list on say Master 5, I build a CM5 macro on the first cue in the list so when I start playback of that list, its master is chosen, allowing for easy editing, record targeting or cue execution in that list.
That works great until the list is on a different master number on a different page or you move the list from one master to another.  Then it selects the wrong master unless you fix the macro.
Could we have something like "CM Current" instead of specifying a specific master number?  CM Current would then select the master that list/cue was fired from If assigned to a physical master of course.  No action if it was not fired from a physical master in this case.
Syntax could be CM0 or CM* acting as a wild card for whatever the current master the list is on.
