Hello,
i am bringing a show to a venue that uses Expression Offline version 3.11 will it be compatible with the Express 350 console that we recorded the show on?
thank you very much for your help
-Alison
Hello,
-Alison
Alison;
You can always open any Expression or Express show in Offline. Have them change the console type in their offline software to match your desk and restart it and you should be good to go. Additionally you can transfer shows between Expression and Express consoles directly by loading the show. The only gotchas you can encounter are:
- If the channel count of the show is greater than the channel count of the console ( in this case the Express 250 will have a lower channel count than any Expression)
- If your show is using more DMX universes that your console allows ( again in your case the Expression line has 3 universes and the Express has 2 so you should be OK).
Be aware of the gotchas if you are taking the show file back wards from the Expression to the Express.
Should you have more questions, please feel free to contact me or anyone in Technical Support.
