When using the console It has a few seconds of lag when typing commands and programming. Any ideas?
Sorry to hear you are having problems.
While this is not a normal behavior to be sure, it has been seen before. I would suggest trying to full system deep clear.
This will clear your show and restore to full system defaults
See how it behaves. If the speed issues go away reload your show and see if they return. It might just be a really big show.
If you still see the problems after a deep clear and before you load your show, it may be indicative of a hardware issue in the processor. If that is the case, contact a local dealer to coordinate a repair.
Hope this helps
