Usinf Expression Offline with lighing System
I know that with ETC Expression offline allows you to program your show before on certain controlers.
But can you run that show off your laptop, with some sort of connector? If so, what kind of connector. Elminating the need for a control pannel.
  • 'Fraidnot.  You're still going to need and Express, Insight, or Expressionlighting desk for playback.  You should also be careful to set the offlineeditor to the correct model of desk and configure your settings to match thereal console before you start programming.  Hope that helps.
    Jim
