Expression 3 Print to PDF Issues
Greetings.
I'm getting ready to update a show file from an Expression 3 LPC to an EOS file and I need to print the cue list, cues, etc.
I'm running the offline editor on a laptop (Windows 11) and when I use the print function from the menu it saves it as a PDF which is great, but unfortunately the columns don't line up. It normally wouldn't be a huge deal but with a few hundred cues to sort through if there's an easy solution or any suggestions I would appreciate it.
  • It's been a bit since I have done this but IIRC rather than printing the cue lists, you can export the show as a CSV file from Expression offline and import it into the EOS.  This should allow you to import patch, cues, subs, and groups. You will need to do some massaging after that.
