Hello,
Does anybody know If an impression 2 or an Expression 2x can comply with midi timecode/ MTC? Also,
Could you tell me how many channels the Expression 2x has?
THANKS in advance!
-Zach
Hello,
THANKS in advance!
-Zach
Answers from this page:
http://community.etcconnect.com/wikis/products/expression-insight-consoles.aspx
midi timecode/ MTC? Yes.
Expression 2x channels? 400, 800, or 1200.
I was viewing the maunal for both Impression 2 and Expression 2x, and It states nothing about midi timecode through out the entire maunal....
Have A look for yourself:
Expression 2x:
http://www.etcconnect.com/docs/docs_downloads/manuals/Expression_2x_v2.0_User_Manual.pdf
pg 267 (PDF page numbering)
Impression 2:
http://www.etcconnect.com/docs/docs_downloads/manuals/Impression_2_v2.0_User_Manual.pdf
Pg 253 (PDF page numbering)
Thanks Derek.
The WIKI manual has links to all the latest versions of software. If you are running a console with 2.0 software I suggest you get the update. I believe that the current software version for those consoles is 3.1. The 3.1 software adds significant improvements and the 3.1 manual has information on setting up time code on the system.
http://www.etcconnect.com/docs/docs_downloads/manuals/Expression_3_v3.1_User_Manual.pdf
this manual applies most of the functions for the impression 2 and expression 2 lines as well.
Page 297
