Hey all,
Quick O2 question for you.
If I have different levels of many channels recorded in a sub. How could I park that sub at full so the contained channels are at their respective levels.
Cheers,
Crispy
Hey all,
Cheers,
Crispy
I don't have and O2 or offline with me, but I think you could go into Park and then use [Group][Sub][x][At][Full][Enter].
Never tried it, though.
That's what i thought too but it just puts the channels in the sub at FL, Not at the percentaged that they are recoreded at in the sub.
It was a damn fine guess though
Hi Chris!
This may work - if you bring up the sub, then with an empty command line type just ENTER (which I think should select all active levels). Then you can type PARK ENTER to park those levels. Anne's going to try it here to make sure.
I hope this works!
Sarah
