Yes there is.. dmx test.. if you press group several times theres a slot named dmx test apears.. then you'll need to press it on the screen.. then you choose witch universe, and the just type in your channel number1-512 and bring it up.
Anders is correct, but please remember to switch out of DMX test mode when finished. If you do not then you will find that your groups appear to no longer function and this usually leads to confusion.
