HOG 1000 <PIG + Pallete>
hey all
Using hog 1000 current version. Normally when you select a fixture from a group pallete, or selecting beam, colour or position palletes you can un-select by holding PIG and pressing the pallete button again. However, when you type into the console GOTO (insert cue number) and press enter, it does not allow you to unselect. Even if I HOG + RELEASE and/or CLEAR/RESTORE the programmer, then reselect fixture, and/or attributes I can not get it to work. I have had it happen in shows a few times when busking and at some point (not sure what I do) it returns.
Any help on this would be much appreciated.
PS. It has happened consistently after Clean starts + on different shows so none of that effecting it.
