Accuscans don't respond to faders
Hello all,
I patched some American DJ Accuscans into a Hog 1000 using the profile provided on this site. The problem is that they don't respond to faders or to blackout. They simply come on when the program is activated, regardless of the position of the master or channel faders.
I changed the 'highlight' paramater to 'highlight = 255', so that the highlight function now works properly. Changing 'paramater = strobe' to 'paramater = Intensity' did not correct the issue, and changing 'crossfade = 1' to 'crossfade = 0' had no effect on the fader issue. Adding 'range = 0, 255, %' caused the fixtures to be on even if a program was not active.
Below is the profile as I have it now.
The strobe and dimming for these fixtures is dmx channel 6, so how can I get them to dim when the master or channel fader is moved?
Thank you,
Ian Ford
fixture = AccuScan
manufacturer = 57
product = 14
name = Accu Scan
output = dmx
parameter = Pan
default = 128
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Tilt
default = 128
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Colour
default = 0
highlight = 0
crossfade = 1
type = ltp8bit
range = 200, 255, rainbow, noauto
range = 0, 19, white, centre
range = 20, 39, red, centre
range = 40, 59, blue, centre
range = 60, 79, green, centre
range = 80, 99, yellow, centre
range = 100, 119, magenta, centre
range = 120, 139, orange, centre
range = 140, 159, purple, centre
range = 160, 179, pink, centre
range = 180, 199, lt blue, centre
parameter = Gobo
default = 0
highlight = 0
crossfade = 1
type = ltp8bit
range = 0, 13, open, centre
range = 14, 27, gobo1, centre
range = 28, 41, gobo2, centre
range = 42, 55, gobo3, centre
range = 56, 69, gobo4, centre
range = 70, 83, gobo5, centre
range = 84, 97, gobo6, centre
range = 98, 115, gobo7, centre
range = 116, 135, gobo1+, centre
range = 136, 155, gobo2+, centre
range = 156, 175, gobo3+, centre
range = 176, 195, gobo4+, centre
range = 196, 215, gobo5+, centre
range = 216, 235, gobo6+, centre
range = 236, 255, gobo7+, centre
parameter = Gobo <>
default = 0
highlight = 0
crossfade = 1
type = ltp8bit
range = 136, 255, <
range = 0, norotate, noauto
range = 8, 127, >>, noauto
parameter = Intensity
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 192, 223, random, noauto
range = 128, 159, pulse, noauto
range = 64, 95, strobe, noauto
range = 0, Closed, noauto
range = 32, 63, dimmer, noauto
range = 255, open, noauto
parameter = control
default = 0
highlight = 0
crossfade = 1
type = ltp8bit
range = 60, lamp off, noauto
range = 40, lampon, noauto
range = 80, allreset, noauto
range = 85, scan rst, noatuo
range = 88, col rst, noauto
range = 91, gobo rst, noauto
range = 0, normlCol, noauto
range = 20, colorPos, noauto
range = 40, norotate, noauto
range = 100, prog 1, noauto
range = 120, prog 2, noauto
range = 140, prog 3, noauto
range = 160, prog 4, noauto
range = 180, prog 5, noauto
range = 200, prog 6, noauto
range = 220, prog 7, noauto
range = 255, sound, noauto
parameter = Speed
default = 0
highlight = 0
type = htp8bit
range = 0, 225, speed, noauto
range = 226, blinkmov, noauto
range = 236, blinkwhl, noauto
