Hi, I created a bunch of palettes that I have since merged into other shows. Specifically the ones that i'm having an issue with are CXI color values. When I send the CXI's to a color, they end up about 1 DMX % level short of being fully in the frame of color. So for instance if red is front string 30 and back string 46, it will be front 29 and back 45. The only solution I can think of to fix this is to re-record all of the pallettes, is there any other way to fix this or has anyone else encountered this?
Eric
