Fixture library
Greetings Hog users, maybe you can give me some advice:
I own a Pearl 2004, and have modified my own fixture profiles to auto generate menus the way I like to lay out the console. I have also included the palettes that I use most, with the parameters that work for me. Lately, I have found myself behind a Hog 2 more than usual, and I wish I could have the same freedom of loading in fixtures and having the palettes auto generate to my liking. Any thoughts on how to do this? Should I alter the fixture library with a text editor like notepad? Or do you users carry around a bunch of disks with your favorite fixtures built into a show and merge the palettes you want for the fixtures you want into a current show?
Also, is there any way to access the individual fixture profiles in the library? I have been able to gather a few from the rom library downloader, but the list isn't complete. I found some issues with the Mac 250 Entour basic profile for the stepped scroll color wheel functions, they don't match the dmx protocol sheet. I "fixed" the profile so the labels now match the colors, but the split color function doesn't work. How do I do this? I read the manual page 173 and rewrote the range = to allow the use of split color functions, but it doesn't work.
Thanks in advance for your help!
Jim
  • Hi Jim, I`ve had the same problem with the library of the mac 250 krypton, here is the library modified so to have split colors
    I think it`s the same whith de entour
    parameter = Colour
    default = 0
    highlight = 0
    crossfade = 1
    type = ltp16bit
    range = 62976, 65535, random, noauto
    range = 58112, 62720, <
    range = 53248, 57856, >>, centre
    range = 52224, 52992, white+, centre, noauto
    range = 51200, 51968, ctc+, centre, noauto
    range = 50176, 50944, yellow+, centre, noauto
    range = 49152, 49920, blue+, centre, noauto
    range = 48128, 48896, pink+, centre, noauto
    range = 47104, 47872, green+, centre, noauto
    range = 46080, 46848, blue108+, centre, noauto
    range = 45056, 45824, red+, centre, noauto
    range = 44032, 44800, magenta+, centre, noauto
    range = 43008, 43776, blue141+, centre, noauto
    range = 41984, 42752, orange+, centre, noauto
    range = 40960, 41728, green202, centre, noauto
    range = 39936, 40704, purp+, centre, noauto
    range = 0, 1280, white+
    range = 1281, 4096, ctc+, centre
    range = 4097, 6912, yellow+, centre
    range = 6913, 9728, blue+, centre
    range = 9729, 12544, pink+, centre
    range = 12545, 15360, green+, centre
    range = 15361, 18176, blue108+, centre
    range = 18177, 20992, red+, centre
    range = 20993, 23808, magenta+, centre
    range = 23809, 26624, blue141+, centre
    range = 26625, 29440, orange+, centre
    range = 29441, 32256, green202, centre
    range = 32257, 35072, purple+, centre
    range = 35073, 39935, white+
    Hope this helps you.
    Best regards
    Ariel
