Hog 500 faderwing
I am going to be using a hog 500 next week. I think I should be able to use a Behringer BCF2000 as a faderwing. I have set it up for use with Hog PC but How should I set it and the colsole up for use with a Hog 500? Does the same setup work with Hog II?
  • I haven't tried this, but you should probably be able to do that.. You will need the computer with the midi-ox conversion in between your bcf, and your hog500.. so you will need to route the midi out from midi-ox to a physical midi output, and hook it up to your hog500.
