Quick question, I am dealing with Hog 2 PC. I would like to change the output of just one deskchannel from a percentage to a DMX Value. Is this possible and how? Thanks in advance.
So what you are saying is that even though you can have it display the DMX value, you can not actually type in the 256 different numbers?
The short story is I'm using it with the Rosco Keystroke. Just for the heck of it it would be great if you could send it to me, because I haven't messed around with profiles much. Check your PM for my email.
yes you can use the numpad, just it works a little different. like I said before, the numpad will work by percentage level and the display of the output will work in dmx value, otherwise you can simply use the jogwheel. you understand what I mean once you load the profile.
