Hello, we are not sure what you are asking. Halt indicates a cue that has been stopped during it's fade in, or you can use Halt to clear the entry in the WAIT column of a cue in a cuelist.
If the cue has a time value in the WAIT column, pressing SET, then HALT, will delete the time value for that cue so that it is now needed to be played manually and will not automatically play.
