Pumping output... when using wing..
Hello all
A problem I already see once in a while fo many years:
Cues which are played from the wing are pumping about 5% up and down on the HTP-channels.. same cue on the console is fine... also fast movements on the faders the cue resp. the HTP-output gets stuck.. same cue on the console: no problem...
This problem shows up, once in a while and disappears, as it comes.. really strange.
I've seen this on several consoles...
Anyone seen anything like this?
Aloha
michael
