I am trying to setup a festival disk for an event and i need advice.
Fixtures supplied will be
Clay Paky Alpha Wash
Clay Paky Alpha Spot HPE
I remember having issues with these before due to difference in fixture profile for either the "ext" profile or the standard profile both of which have the same channel count.Can someone clarify if both versions work on a Hog II??
The festival console is an MA so am trying to get the lighting system to work for both consoles with fixture profiles that work for both also.
Regards C
