Clarification on 'Reduce to %'
I have been using 'Reduce to %' on desk channels patched to multiple outputs. When I am building my patch, I am assigning outputs individually and using 'Reduce to %' each one. It's fine for the first output assigned, but when I assign the second output, the reduce to % from the second output overrides the reduce to % on the first output. Any ideas?
Dan
  • If you need two different %% for two different dimmers, then you will need to assign two Desk Channels to accomplish this.
    So add 1 Desk Channel for every instance you need this.
    The desk will reduce by user number/fixture....not by dimmer within said fixture.
