loading hog II show onto IPC
How do i need to do this to get it to work properly? I know the IPC does not have a floppy drive. I am thinking i will just drop the whole hog show into a file on a usb drive then load that up from the console. Am i doing this correctly? I am waiting for the show to be e-mailed to me. I currently do not have the IPC but i have hog 2PC, i can try it on.
  • Hi,
    Yes you are going about this in the correct manner.
    Either save your show on Hog II PC to a USB stick or burn it to CD and transfer it to the IPC console.
    I bought a USB 3.5 floppy drive that i connect to my IPC console,they are cheap and you can get them online or most large computer stores.
    Just means i can load direct to an IPC from a floppy disc.
    C
  • Tim,
    Please be sure to place your entire Wholehog 2 show file into a folder on your flash drive. This way you can select the folder to load into the Hog iPC console.
  • Thanks for the tips guys. I was thinking about picking up a USB floppy drive too many computers out there that dont have a floppy drive and i usually end up needing a floppy drive.
