Ok here is what I am wondering now.... I want to create an Effect or Pallet that would scroll through the RGB colors of an LED.... The light does not have a scroll function. I can create the look and assign it to a fader, but would like to create it as a pallet or effect since I use it quite often and would like the ability to fan it and change its rate..... any suggestions would be great..... I have tinkered arround with the effects engine on the hogII and cant seem to get it to look smooth and transition between red green and blue evenly..... Thanx in advance
Hello, if you want specific color changes and order, it is best to build it as a chase as you have already done. You can try putting a sine wave on each color. One color would have SINE, the next SINE +180, and the last SINE +270. This will create a rainbow or color scroll effect but the color order etc is not as controllable as a manual chase.
