Hi
I have an LED fixture with an intensity channel.
The intensity channel runs 0-240 (ish) DMX gives 0-100% brightness, but then at 240 the unit snaps off, and stays off up to 255.
Is there some way I can make the intensity parameter in the fixture library do this ie when the unit is sent to full the DMX value is 240, not 255? And also so that once you wind the encoder up to DMX 240, the output stops there if you keep winding.
(I know I could limit the DMX output in the patch, but I want to do it in the library so that I don't have to make the extra work!)
