jands hog 1000 and fixture library
hi guys
i've to make a show with a jands hog 1000 using some ROBE 700 EA T. How can I find to download the devices for this kind of fixture?
It's possible to load an Hog 2 show in a Jands Hog 1000?
thank you
paco
  • [quote=paco toscano]hi guys
    thank you
    paco
    Hog 1000/Hog 500 and Hog-2 are pretty much compatible as far as shows are concerned. Hog 2 to Hog 1000 is pretty clean, but Hog 1000 to Hog 2 can get interesting, since you don't have the number of playbacks on the -2 as the -1000, so you need to go relocate some stuff. As far as fixture libraries and such, they are identical - if you use the library generator from HES for the Hog-2 for your Robe, it will run perfectly on your 1000.
    - Tim
