Hog 500 lib file hex code.?....help
First time updating a fixture library. Downloaded the new fixture files and opened the lib file with Text Pad.
File contains lots of hex code with text on the right margin....can't seem to edit anything.
Any suggestions?
  • [quote=Hourglass]Hi,
    Any suggestions?
    You have the wrong file. The correct library file is pure text, and looks like:
    fixture = Ibeam13
    manufacturer = 2
    product = 9
    name = Ibeam 13ch
    // require ML25F ver 3.04
    // Dip switches (personality)
    // 3 on dmx address 1-256
    // 4 on dmx address 257-501
    // 7 off is oscillating colours, on is split colours (?)
    // for following modes set [5] [6] [8]
    // 7 channel [ ] [ ] [ ]
    // 8 channel (+speed) [ ] [ ] [X]
    // 7 channel (hires) [X] [ ] [ ]
    // 8 channel (hires+speed) [X] [ ] [X]
    // 12 chan ext [ ] [X] [ ]
    // 13 chan ext (+home) [ ] [X] [X]
    // 11 chan (no csum) [X] [X] [ ]
    // 12 chan (csum) [X] [X] [X]
    // Set personalities to 3, (or4), 6, 8 all on (other off)
    output = dmx
    parameter = Pan
    default = 32768
    highlight = 0
    crossfade = 0
    type = ltp16bit
    deflection = 170
    range = 0, 65535, %
    parameter = Tilt
    default = 32768
    highlight = 0
    crossfade = 0
    type = ltp16bit
    offset = 0
    deflection = 110
    range = 0, 65535, %
    parameter = Colour
    default = 10
    highlight = 10
    crossfade = 1
    type = ltp8bit
    range = 10, white
    range = 23, pink
    range = 43, turquois
    range = 64, dk pink
    range = 86, green
    range = 107, purple
    range = 128, yellow
    range = 150, blue
    range = 171, red
    range = 192, congo
    range = 214, orange
    range = 235, cyan
    parameter = Colour <>
    default = 15
    highlight = 15
    crossfade = 1
    crossfade = 1
    type = ltp8bit
    range = 15, solid
    range = 47, *solid
    range = 79, shake >
    range = 111, shake >>
    range = 144, >>
    range = 175, <<
    range = 207, split
    range = 239, *split
    parameter = Gobo
    default = 10
    highlight = 10
    crossfade = 1
    type = ltp8bit
    range = 10, open
    range = 23, dot
    range = 43, phones
    range = 64, shatter
    range = 86, line
    range = 107, playschl
    and so forth . . . . . .
    Is the file you downloaded perhaps zip compressed, and you forgot to extract it?
    - Tim
  • Thanks Tim,
    Yes I guess the LIB didn't unzip completely. After using a differant text editor I was able to edit the file and load the new fixtures.
    Day two with the hog....learned a lot.
    Steve
