Creating PreFocus Pallettes on Hog2PC
Someone kindly direct me to a previous posting or respond to the following question.
I am running Hog2PC which I will be transfering the files to a HOG1000. My question is this. In my installation I have several moving lights. I am creating prefocus palletes so on a whim I can move any given light to a predesignated position, then fine tune as need.
So far, I have created prefocus palletes for Pan/Tilt values. I have recorded Pan values at 50%, and changed the Tilt values by +/- 4% values, and have done the same for Pan values (Tilt at 50% and Pan +/- 4% increments).
What I want to do is using the prefocus palletes which either adjusts one parameter lets say Pan 50%, Tilt 12%. I want to be able now to preadjust the pan value while retaining the Tilt value.
Is that possible and if so how do I implement without having to manually adjust the desired values?
Thank you.
Email sstew998@verizon.net
