Hog2PC Question
Another question on the Hog2PC. The Hog2pc has only 8 faders. Assuming that files created on it are compatible with the Hog1000, how dow you load queues created on the HOG2PC into faders 8 thru 16 on the Hog1000?
Also, if you load a show created on the Hog1000 to a PC running Hog2PC, if the original shows were saved to faders 9 thru 16 on the Hog1000, in what faders are they defaulted to when the show is loaded in Hog2PC?
Finally, what is the maximum no of pages you can create on the Hog2PC?
Thanks for the response,
Stevenson
