Problems putting groups at full
Hi All,
I have a problem on a WholeHog2 where I will create a bunch of groups, and then when programming, 75% of the time, if I type GROUP # FULL the group becomes selected in the programmer but not set to full....I have to type @ 100 ENTER after what I have typed above to put it at full. Also, I occasionally get error messages on the command line when setting levels or other parameters on equipment. The show where this was presenting the most trouble was a show with ~200 desk channels and one DMX strobe (which I had to create a library disk for). Anyone seen this sort of behavior before/have a good fix? I've tried resetting the console with a cold start to no avail. The issue becomes very frustrating when using older/dimmer lighting equipment that needs to be put at full often.
Stevan
