I was wondering if i could make a personality for an RGB fixture that does not have a dimmer channel. I would like the hog to act like it has a dimmer, its a pita to go into a blackout and have the LED's still up. Also has anyone made a personality for a Mega Lite 1100 axis led? megasystemsinc.com/megasys/megalite/product.asp?MName=AXIS%20LED
If you use a custom profile that has all the RGB channels treated as "Intensity" parameters, your LEDs will dim with GM and fader movements......not the same as an overall virtual dimmer though.
