Hog 2 Loading Issues, from Floppy...
Hi Guys,
I am having an issue with loading a show of a Disk.
The desk has been known to have some issues, so I wanted to test the save/bootup...
So, I saved a show called 'test' to the Disk, which it did fine.
Then, I loaded a new show, then from there tried to load my old show again. And, it says there is a problem with loading the disk, which is odd, as I saved to it earlier...
Change of disk, and it does the same thing. Saves to the disk successfully, but won't load up from it.. The message I am getting is that the function.txt has been modified, the show won't load properly. When I say load the show anyway, it then tells me that it can't because of the version of software isn't compatible...
I am totally confuzzled, as this is the exact same show I programmed on the desk, which it will now not load...
Any ideas/advice? If Dave Lewing is on this forum, its the you fixed the other day - number 847.
