HOG 2 Compatibility Question regarding XPe Image
Hello Fellow Squintz and Button Pushers -
I am about to update a HOG IPC that is used in a theme park attraction. The attraction is programmed in HOG II, and I need to program the special event on the same console in HOG III. I need to update the HOG III software to the current release (It's now 2.6.0!), and it was recommended that I update the XPe Image, as well.
The current HOG II show is SMPTE time coded.
The HOG II software is the final release.
My question is: Are there any issues I need to be aware of regarding this updating process having negative affects on existing HOG II show files?
Rob Fritz
Lighting Designer / Programmer
AirLight Design
