Im new to the Hog 500 and basically taught myself to to use it. I recently got 4 new LED movers and i made the profile for them for my Hog 500. The pan/tilt works fine and some random built in effects that just continuously cycle through the colors. I cant turn the intensity up for an RGBW individually. Can someone tell me what i did wrong with my profile.
version = 40
count = 1
fixture = Elation
manufacturer = 55
product = 25
name = Elation ledpro
yoke = yes
output = dmx
parameter = Pan
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Panfine
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Tilt
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Tiltfine
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Red
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Green
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Blue
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = White
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Strobe
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 31, leds off
range = 32, 63, leds on
range = 64, 95, strobe e
range = 96, 127, shutter
range = 128, 159, shutter
range = 160, 191, shutter
range = 192, 223, random s
range = 224, 255, shutter
parameter = Intensity
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Rainbow
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 7, no funti
range = 8, 231, rainbow
range = 232, 255, cross fa
parameter = Speed
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 225, max to m
range = 226, 235, blackout
range = 236, 255, no funti
parameter = Reset
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 79, normal
range = 80, 84, all moto
range = 85, 87, scan mot
Steve
stevebearse90@gmail.com
