Recently has started to work on this console and has faced a problem at record CMY on faeders I can not achieve colour merging one colour works only. How correctly to write that worked?
Thats due to the reason that the console works with the LTP concept.
I think you would like to have C on fader 1, M on fader 2, Y on fader 3? Is that right? To do so, you must tell the console to keep color parameters seperated, then record just C at full on one fader, M at full on the next etc... Then put these 3 lists to crossfade IFCB in the cuelist-options
