Hog 1000 Knockout Button
Pardon my ignorance. First time on a Hog 1000.
Just where or how do I access the "Knockout" button on the Toolbar LED menu?
Trying to get an effect out of a Q (amongst other things) and I can't seem to manage the correct keystrokes to get Knockout on the toolbar. I see:
Okay|Follow|Learn|Mark Q|Link Q
Opening the Effect Library I get
Merge|Remove|Track Fwd|State (with Merge and Remove unselectable)
below that is:
Okay|No Fx (again unselectable)
Sorry for the lame question.
JY
  • [QUOTE=jytessier;45949]Pardon my ignorance. First time on a Hog 1000.
    below that is:
    JY
    Knockout shows up on the screen just above the main display, second button from the left. Unfortunately, knockout does *NOT* take portions of a cue out - it knocks entire fixtures out of a cue, and that's it (unless I have been missing something for years . . . ) and is, IIRC, on the second button from the left.
    So typically its:
    If you want to clear say pan and/or tilt, hold down "undo" and move the appropriate encoder . . . or whatever parameter you are trying to clear . . .
    - Tim
