My Hog 1k only has Varilite 1000 TS in the fixture library but someone else I know has used this board with the same fixtures properly.  Hog 3 calls these lights TSD because they have built in dimmer.
When using the varilite TS from the fixture library it seems that the board sees two parts with this fixture.  So when I call it to patch it says "Varilite 1000 intensity" or after hitting fixture part button, it says "Varilite 1000 Pan".  The problem is whatever I patch first is the only thing that works.  So either I patch "intensity" and the lamp works or I patch "pan" first and I have movement of the fixture.
I have a hog3 in the next room and it worked fine with the same fixtures. So its definatly something with the Hog 1k.  Also called High End and they recommended I update the fixture from the most current library however that did not work either.
Anyone gota clue?
